starting problems when hot 2000 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2005, 05:29 PM   #1 (permalink)
View cee710's Photo Gallery
USA starting problems when hot 2000 corolla
hi i have a toyota corolla ce 2000 for 1 week now i have been having starting problems
when the car warms up to normal temp or driving for a while and i shut it off and try to restart it it wont start i have to wait about 3 - 10 mins . anyone know what i should check for the engine light is off the car has about 47k miles thanks. p.s the battery is good,the engine turns over it trys to start and when i get it to start finally if i press the gas hard it sounds like it bogs and a few seconds later its ok i dont know if it bogs becuase i am pressing to much on the gas when trying to start it .thanks again. the car does not shut off when driving only on starting when warm.
cee710 is offline   Reply With Quote
Old 03-25-2005, 06:15 PM   #2 (permalink)
foodaa's Avatar
View foodaa's Photo Gallery
When you try to restart, does the engine turn over normally or does it sound slower then usual? Heat can cause higher resistance to the starting system.
foodaa is offline   Reply With Quote
Old 03-25-2005, 06:19 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Its called heatsoak.. my car and many other older Corollas do it.. the starter gets heat soaked with the heat from the manifold.. and it won't start until it cools down.. trust me man.. its annoying in the summer.. having to push start your car..
Old 03-25-2005, 06:36 PM   #4 (permalink)
yes the engine turns over normally it takes about 3 min and more to restart the car .
Old 03-25-2005, 06:38 PM   #5 (permalink)
its a automatic i cant push start mines i got the car in 2000 and it was running great until a week ago .
Old 03-25-2005, 06:50 PM   #6 (permalink)
View Corolla_Dude's Photo Gallery
Hmmmm maybe try fuel injector cleaner for that injectors
That might help
It might not either
Corolla_Dude is offline   Reply With Quote
Old 03-25-2005, 06:52 PM   #7 (permalink)
View phil's Photo Gallery
Does that happen everytime?(when hot)
or only once in awhile?
phil is offline   Reply With Quote
Old 03-25-2005, 06:58 PM   #8 (permalink)
That might help
It might not either
hi i could try that im trying to do some research on the web i came across this i dont know
i have to find out if the car has ignition module,efi relay over heating or if its having a vapor lock or fuel injector problem efi. ill keep looking i hope to get a repair manual soon .
Old 03-25-2005, 06:59 PM   #9 (permalink)
hi phil does it all the time when hot
Old 03-25-2005, 07:07 PM   #10 (permalink)
KDM is in
REN69's Avatar
Its nothing fuel related.. its the starter.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 03-25-2005, 07:12 PM   #11 (permalink)
hi REN69 ill look into the starter also just trying to break it down to what components are causing this to happen thanks for all u guys input thanks
Old 03-25-2005, 09:44 PM   #12 (permalink)
foodaa's Avatar
If the engine starts when cold. Its probably not the starter itself. However, its possible that there may be some resistance in the cable from the battery to the starter. Try cleaning battery posts, clean the connection at the starter.
Old 03-27-2005, 06:00 AM   #13 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
How long since the sparks plugs were replaced? Also could be a hot soak problem with the winter blend of gas contributing to the problem. Have you tried holding pedal down slightly while cranking? That generally works for my older fuel injected corolla when it takes longer than usual to start.
90 GP is offline   Reply With Quote
Old 03-27-2005, 09:24 PM   #14 (permalink)
hello the spark plugs where never changed its got 47k miles about i just noticed something else today it might have to do with the problem im not sure when im driving and if i floor the gas pedal lets say about 10 -20 miles per hour or higher speeds the car bogs hard hesitates
its like if its going into nuetral do i have 2 problems or could it be one problem causing this like if the car isnt getting air or something the o2 senors where both changed the engine light is off the air filter is good i opened the box where the air filter is ,is that the air intake? i looked for a few mintues ill look again tommorrow was to busy today thanks again for all the help p.s if i floor it when cold its fine takes off and runs good only when driving for a while,i did fill up the gas 2 times snice this has been happing with 2 different gas stations moblie 93 and sunco 93 or 94 i always used mostly does gas stations.
Old 04-05-2005, 04:42 PM   #15 (permalink)
all
hello i took the car to another tech he scanned the computer and everything was good,he did find the problem it was the air flow sensor car runs good and starts right up.thanks for all the help !!!
