4A-LC timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2005, 06:42 PM   #1 (permalink)
View novarolla's Photo Gallery
4A-LC timing
I got my old 1986 4A-LC (SOHC) back together but can't get the timing set to 5 degrees BTDC, that is what the VECI label shows. I tried pulling the distributor out and moving the gear one cog several times. I either end up to far retarded or as close as I can get BTDC is 10 degrees BTDC.
Do I dare leave it set there?
Is there a web site where I can learn more about the carburetor on that engine?
Thanks for any replies.
novarolla is offline   Reply With Quote
Old 03-26-2005, 08:51 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
if it doesnt spark knock or crank over hard, leave it at 10, it sounds like the timing belt is 1 tooth off?
Old 03-26-2005, 09:57 PM   #3 (permalink)
fredk,
Thanks, I didn't think of the belt. Yes, I will leave it considering the work to get the timing belt covers off again. The water pump pulley location was thought up by somebody who never had a wrench in hand....
Thanks again.
I was concerned that 10 degrees BTDC might cause some early engine troubles, but it seems to run well. I better try a carb kit yet too.
Old 03-27-2005, 05:36 AM   #4 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
I used to have an 87 Nova and remember that to adjust the timing you had to remove the vacuum lines and plug them prior to doing the adjustment. If this step was ommitted it would change the ammount of adjustment you would have to work with.
90 GP is offline   Reply With Quote
