7afe pumping oil like nuts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2005, 09:44 PM   #1 (permalink)
View Cabanon's Photo Gallery
i have a '93 LE with a 7afe in it and in less than 3000km the engine pumped like an entire gallon of synthetic oil and that pissed me off cuz thats like 55$can in the garbage
any1 would know the problems?
there's no blue smoke, no leak, thats kinda weird..
'93 AE102 LE 1.8 5spd
'77 TE31 Deluxe 2TC 3spd Auto
Cabanon is offline   Reply With Quote
Old 03-26-2005, 11:51 PM   #2 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Why use synthetic?
But anyway, you sure youve checked well for leaks? Idle the car in place for like 10 min and then see if there's oil on the ground.
Hope someone else can help.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 03-27-2005, 12:58 AM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
hey, i got the same friggen problem...let me guess it doesn't smoke on startup, it doesn't normally smoke, and there are no oil leaks.. and the harder you drive the faster it "disappears" i found something wierd on mine...
All i know is that its comming from the PCV system, collecting here and dumping down the intake as to why its there i have no freeking idea i passed it by a tech at the local toyota dealer and he had no idea.. no one on here seems to know either.. im thinking of putting together a group of 7A-FE'ers and asking toyota to help us with a solution to this problem
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 03-27-2005, 03:31 AM   #4 (permalink)
View cobrajet25's Photo Gallery
How is your compression? The only way you would get that much oil in your intake via the PCV valve is if the engine has a lot of blow-by, right? You may just have worn rings. Regards, Aaron
cobrajet25 is offline   Reply With Quote
Old 03-27-2005, 10:14 AM   #5 (permalink)
Originally Posted by Ukrainian102
Why use synthetic?
help motor to last longer and i get 50km+ per tank
gotta check for the compression the week and let you know
my friend told me about the pcv valve too
dunno what the fuck is does, but he changed the pcv valve on his rolla cuz it was pumping oil too and it dosent anymore.
hope this could solve my problem
