Hey clumzy!
Yep, you got it right about the rust. While you're down there, check for any kind of leaks (diff, tranny, engine oil, prestone, gas tank), check for holes in the floor, rocker panels, etc... When you drive it, check for any noises coming from the diff or tranny. Another important thing is to check the oil pressure, should be between the two ines. Even though Toyota gauges are reknown to lose their precision with time, an out of spec oil gauge is not pointing in the right direction.
Opinions are like assholes, everybody has one.
TOYODORI - The Quebec Toyota enthusiasts club - www.toyodori.com
