Brake Question !! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2001, 08:06 PM   #1 (permalink)
View pureimport's Photo Gallery
O.k when I went to work this moroning, I just left my drive way and I applied the brakes. Fine. But then when I applied it a second time it made a noise simalar to when u have snow in between the fenders or snow crunching. I turned off the radio to hear it again and it was still there. When I Broke at the next light it was gone.
When I got to work I noticed that my rims had a coffee colour substatce (brown) on the front driver side. It ran all around that rim only, when I touched it, it was kinda grainy. what could be the problem
Btw I have ABS brakes
Thanks in advance
Damian
pureimport is offline   Reply With Quote
Old 10-01-2001, 08:42 PM   #2 (permalink)
Banned
View goodcookiedrift's Photo Gallery
prolly something with the brakepad. I would pull off the front tires and check them...inspect to see if there are any grooves or striations on the rotor...if so, you have yourself either a warped rotor, faulty caliper or possibily one of the anti-vibration shims are rubbing. that brown stuff is just brake dust. it will build up overtime, esspecially if you have cross drilled or slotted rotors.
check your lines and master cylinder to see if there are any leaks, cracks or ruptures. Play with the brake pedal to see if the pressure is ok...is it too soft or too stiff? is there an inconsistent pressure...like stiff, stiff, soft, stiff...might need bleeding?
finally, check your brake pad to see if its worn past the limit, wearing uneven or if there is any grease on it. superficial grease should just burn right off, but if theres a superfluous amount, it will cause uneveen braking. best bet is to wipe down the rotor and even the pad with some gasoline and a rag. Check the back drums too (or rotors if you have). make sure that the parking brake is not too tight or even siezed to the point that it rubs even when its not engaged.
its hard to assess the problem without seeing it or experiencing it. But if you do some of these things, then at least you can limit the possibilities or even pinpoint the problem.
goodcookiedrift is offline   Reply With Quote
Good discussion on x-drilled/slotted brakes EKam Hardcore Tech and Competition 44 12-29-2003 11:46 AM
Changing Brake pads ...Dealership? danny67x Camry & Solara Lounge 1 06-25-2002 01:36 PM
Stainless Steel Brake Lines SpectraBlueCam General Discussion 7 11-30-2001 05:06 PM
Demand for SS Brake Lines??? FrYdRyCe Camry & Solara Lounge 6 10-30-2001 10:52 AM
wheres a good custom big brake kit? henry bui General Discussion 8 09-13-2001 07:31 AM
