Originally Posted by evilinside
yeah...kind of figured i would need a new lateral control rod.....how did you make yours???.....i was thinking couple of heim joints/rod ends.....and aluminum tubing....
why would there need to be any modifications to the strut casing for a coilover set-up???.....unless that has more to do with replacing the strut....OR....is it for the strut itself to sit a little lower???....
you ONLY need to modify the strut casing if you're using a short stroke shocks. there's lots of talk about it at club4ag. check it out.
