rattling and vibrating sound - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2005, 12:09 PM   #1 (permalink)
View pabuccu's Photo Gallery
When I start the engine up once in a while I hear a rattling sound as if something is hitting against the hood. I changed the engine oil but it still does it. It started to do the same when I turn off the engine.
Also, while driving at low speeds I'm hearing a vibrating sound as if something is loose like the exhaust pipe and hitting the road. It's not there at high speeds.
Engine sounds fine at idle and while driving.
This is a 2000 Corolla with 50,000 miles on it.
Thanks
pabuccu is offline   Reply With Quote
Old 04-01-2005, 12:19 PM   #2 (permalink)
05 Lemon
View Excidium's Photo Gallery
Sorry to hear about your problem pabuccu. Maybe you have a loose heat shield. It's kinda hard to help when I can't hear it for myself. I hope this helps my 97 use to rattle sometimes and it was the cat shield that was loose.
Excidium is offline   Reply With Quote
Old 04-01-2005, 02:02 PM   #3 (permalink)
View 89TCGTS's Photo Gallery
its kinda hard to tell what any vibrating sound is just from an explanation, but another possibity is that your cv joints are going out. When on the road(going straight) my corolla's cv joints rattle. That is because the boot is completely gone from it. You could probly ask a mechanic to tell you what it is for no charge.
89TCGTS is offline   Reply With Quote
Old 04-01-2005, 07:00 PM   #4 (permalink)
View karugs's Photo Gallery
Get a mechanic's stethoscope and probe around. Best $10 you'll ever buy
That same device helped me trace my alternator going bad, since mine is a loud diesel you can't just isolate one sound by putting your ear close to it. I had to use that steth, and it worked great.
karugs is offline   Reply With Quote
Old 04-14-2005, 10:14 PM   #5 (permalink)
J
View 05 toyota's Photo Gallery
its fine if sounds are not too loud, i had 05 corola brand new and soemtimes when i start up have some rattling and vibrating sounds, when i took back to the dealership they said its fine....i guess i can trust them
05 toyota is offline   Reply With Quote
Old 04-14-2005, 10:52 PM   #6 (permalink)
A brand new car has rattling sounds?
Old 04-15-2005, 07:02 AM   #7 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
Agreed - heat shields would be first place I start looking for them kinda rattles (also agreed hard to say without actually hearing it)...have had that happen on a couple of former cars - not really bad for the car, per se (as long as it doesn't come flying off at highway speeds) but the "rattle" IS most annoying !!!
PhantomS is offline   Reply With Quote
Old 06-24-2005, 01:37 PM   #8 (permalink)
View Irene's Photo Gallery
Canada
I had similar sounds in my 97 Corolla last year, and it turned out to be a cracked manifold and worn off engine mounts. Once I had those replaced, the vibration went away.
Irene is offline   Reply With Quote
