turbo problem??>>>white smoke>>?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2005, 07:25 PM   #1 (permalink)
View corolla_racer's Photo Gallery
hey guys
i have a 1.8 and its 95 corolla turbocharge......My qesution is that my car just strated to smoke..It smoke white smoke and i now think that my oil is mixing into it anti-freeze....thats why its smoking.......So what do you guys think??.... blow head gasket???? or somthing eles....Please help me out i'm going to go run it at the traek next weekend..............THANKS
corolla_racer is offline   Reply With Quote
Old 04-01-2005, 07:55 PM   #2 (permalink)
View LonelyDriver's Photo Gallery
white smoke usually means water vapour. check to make sure all your hoses are connected properly
LonelyDriver is offline   Reply With Quote
Old 04-01-2005, 09:31 PM   #3 (permalink)
any eles wrong????/
Old 04-02-2005, 12:09 AM   #4 (permalink)
Gameroom cash: $134355
probably a blown head gasket....... fix it and have your head decked
Old 04-02-2005, 12:12 AM   #5 (permalink)
View Fabius's Photo Gallery
check your head gasket might be burning coolent
Fabius is offline   Reply With Quote
Old 04-02-2005, 07:32 PM   #6 (permalink)
Noob :-)
View ST185's Photo Gallery
White smoke can be caused by blown turbo or blown headgasket.
Open the oil filler cap and see if you find any trace of coolant (milky white stuff).
How is the turbo shaft play?
93 ST185
ST185 is offline   Reply With Quote
Old 04-03-2005, 07:15 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
blown turbo would cause black smoke. Lots of white smoke is usually head gasket problem.
Old 04-03-2005, 07:04 PM   #8 (permalink)
well it depends on how the turbo is cooled and/or which line gave...... there are turbo's that are only cooled by the oil that passes through them, so you wouldn't have white smoke coming from a turbo with shaftplay....
Old 04-04-2005, 06:15 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Well the waterjackets in turbos usually arent connected directly with the shaft, so unless your turbo housing has cracked it wont leak to the engine. Shaft sealing problems cause oil leakages, causing black smoke.
Old 04-04-2005, 07:01 PM   #10 (permalink)
View 89TCGTS's Photo Gallery
does it smoke only when you start it up????if thats the case then it's probly oil burning. I don't know if it just happened all of a sudden or what but that could be the problem. Antifreeze usually burns kinda blue......if it looks blue than you probly have a blow head gasket or a cracked head. I don't know anything about turbos so that could be the problem too.
89TCGTS is offline   Reply With Quote
Old 04-04-2005, 09:36 PM   #11 (permalink)
View karugs's Photo Gallery
I thought white smoke meant coolant burning? (headgasket)
Blue smoke is oil burning (as in the case of valve stem seal problems)
karugs is offline   Reply With Quote
Old 04-05-2005, 02:40 AM   #12 (permalink)
i DON'T THINK ITS MY HEADGASKET, BUT WHEN I LOOKED AT MY COOLANT SYSTEM I DON'T SEE ANY OIL IN IT AT ALL...i JUST DID A COOLANT FLASH SO NO CLUE MAN...THIS SUCK ...HEHEHE...THE TIME IT SMOKE ONLY WHEN MY CAR IS HOT AN WHEN I PUSH MY CAR.....
Old 04-05-2005, 02:45 AM   #13 (permalink)
Resident asshole
Flashmn's Avatar
You smoking crack or something? Antifreeze burns white, oil burns blue.
I didnt see any oil in my coolant system, nor any coolant in the oils, yet my headgasket was blown.
