Not really sure about how to take the door off on a 98.
On a 93-97 you take the mirror adjuster cover off, pry out power window/lock controls and disconnect the wires, pry up the hand rest and unscrew two screws from under it, and then take the door handle screw out and pull the door handle toward the front of the car and then out. Then pry the door trim off.
In any case, if you still hear the power door lock sound coming from the door when you press the button, just the lock doesn't move it's not the actuator.
I had a problem with mine, rear left power door lock seemed to only go down half way. The sound was still coming from the door though, so when the dealer told me I needed a new actuator I knew it was b/s.
I took the door apart and WD-40'd everything in sight and all the locks worked perfect after that.
Anyway, I think it just needs a little oiling up!
