I'm basically stuck on the wiring part hoping you have some insight before i start running wires from diagrams. I have everything plugged where it needs to be, exept the wires that go inside the car dont have anything to plug into...sr5dashboard/ignition switch
Anyways, on that third ecu plug that goes inside (dashboard), i have it but its cut and can't really run the engine without power feeds, ignition switch etc...you have any thoughts on what i should do?
BTW you may like this, it has the 20v wiring diagrams and ecu pinouts for both 16v (inc 4agze) and 20v engines:
http://www.turbocorolla.com/tech/default.htm
i dont know if the gts dashboard/dash harness works, but let me know
