A/C advice and also ABS light on
Hello all, this is my first post in this forum. I have a 1993 Corolla LE with 44,000 miles. The A/C works fine for the first 10 minutes and then the compressor stops cycling and the air turns humid and warm. Don't know why this is happening. Any suggestions. Also, the ABS light sometimes goes on/off and then stays on after I start the car. Sometimes, it doesn't stay on but sometimes it does. I thought it might be a low voltage condition from a relatively drained battery. When I replaced the battery, the problem went a way for a little while. Car was sitting for a month, and then the problem started again. Any suggestions? Thanks very much
