New cap, still no gas tank pressure? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2005, 12:03 PM   #1 (permalink)
View 1sthumper's Photo Gallery
Question New cap, still no gas tank pressure?
Thanks in advance for helping the newbie. My 01 Corrola is more technologically advanced than my 84 Civic! My check engine light is on. I replaced the gas cap cause I wasn't getting any pressure in the tank. I'm still not getting any pressure in the tank with the new cap. What's the next logical step? Thanks again!
1sthumper is offline   Reply With Quote
Old 04-06-2005, 12:36 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Pressure in the tank?
No no, you dont get pressure in the tank, the pump SUCKS fuel out of there.
Old 04-06-2005, 12:46 PM   #3 (permalink)
I was told that the woooshing noise your gas tank makes when you remove the gas cap was important to the whole emissions deal? And that's why my check engine light was on because the tank wasn't building any pressure, so I replaced the cap. I still don't get a woooshing noise when I remove the cap?
Old 04-06-2005, 06:27 PM   #4 (permalink)
foodaa's Avatar
View foodaa's Photo Gallery
You got it. Your gas cap must be able to hold pressure for emissions. Use your old gas cap.
foodaa is offline   Reply With Quote
Old 04-06-2005, 11:51 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
That would be vacuum most likely.
Old 04-07-2005, 04:47 PM   #6 (permalink)
View karugs's Photo Gallery
Foodaa is right, if your old gas cap makes that wooshing sound it's normal since the fuel tank creates vacuum as fuel is used up. When you open the gas cap it sucks in air due to vacuum, not blows out air due to pressure.
So if the old gas cap made that sound, return the new one and use your old.
karugs is offline   Reply With Quote
Old 04-07-2005, 08:05 PM   #7 (permalink)
View karazy's Photo Gallery
If the new cap is OEM, the next step would be to check for obvious leaks or get the system pressure checked. There is probably a leak elsewhere.
karazy is offline   Reply With Quote
Old 04-08-2005, 02:50 PM   #8 (permalink)
BigWilly ;)
View rated_w's Photo Gallery
tighten the gas cap till you hear 5 clicks. then reset your ECU .. if the CEL still turns on you either have a leak somewhere or a bad cap
rated_w is offline   Reply With Quote
Old 04-08-2005, 04:15 PM   #9 (permalink)
Thanks all. I just assumed it was pressure similare to removing the cap off of a portable gas can. The vacuum makes sense, of which I get none, with the old or new cap. I'm going to reset the pesky cel this week end and see how it goes. Thanks again.
Old 04-08-2005, 10:36 PM   #10 (permalink)
View 81SR5's Photo Gallery
Why is your light on? Did you have it scanned? If not, how do you know it has anything to do with the evap system?
81SR5 is offline   Reply With Quote
