16v MAP conversion
Before someone tells me to search, I did. Yielded results for the 20v not for the 16v. Now as we all know the JDM 4AG puts out roughly 10hp more than its USDM counterpart due to ECU tuning (easily overcome) and use of a AFM compaired to the JDM's MAP sensor due to emissions standards. Now I've thought about it and I thought "Hey, maybe I can boost the USDM 4AGE by 10hp easily by converting it to MAP sensor." Now I know if you get ahold of a JDM ECU and harness you can do it, but are there any alternatives to spending a few hours swapping the harness and making sure everything was done right so your engine doesn't get pissy with you? I've thought about using the Greddy Emanage and its optional MAP sensor harness for the job (and hey don't have to worry about getting the ECU, harness, and then tuning that). Now has anyone had any experience doing something like this?
