Here is an image of the same engine before anything else, but it's not the actual one. 4AFE?
Aaron, there are two hoses from the valve cover. One ends on a blue thing at the end of the intake manifold, and the other ends at the throttle body/intake tube (it's origin on the valve cover is also angled). Which of these two is the one leading to the PCV valve? I understand the EGR is behind the intake manifold, somewhere between the hoses when you look at it from the front. I'll keep the engine swap in mind. I just received word that mom will leave it at the shop overnight so I'll pick her up later this afternoon.
On second look it seems there is another hose from the valve cover. Starting from left to right, there is one going to the throttle body(1), there is one going to the blue thing behind intake(2), and another going straight backwards to the intake just to the left of the throttle pulley(3).
PPW, dude are you Pinoy? It seems from your license plate you are. Kamusta? Anyway, yeah I think it's the 4AFE motor I have (see image above). By memory it seems the area below the exhaust manifold is kinda dry (and with wet spots) but I'm not sure if the wet spots are from the busted piston rings (I hope not) or from past grease spots that were never cleaned. If the car is just run then you switch it off and you see wet spots, will this be enough to tell it's piston rings? Or will that just mislead me more since it could be from another fluid (like grease on the engine block)?
Molavi, I don't think the car burns any oil. I haven't observed it that keenly yet. Seems to me that it's not but when I last checked, the oil pan seemed to be wet. But not sure if it's from coolant from previous problem we had. Needless to say, I'll go check it again when I can, as we'll leave it in the shop overnight. Yes engine was warmed up since we did some full throttle runs before testing for smog (but it still failed) and gauge was reading normal operating temps (halfway).
One more question: how do I clean the EGR valve? Do I just take it out? Nothing to worry about or expect to run across? Will soap/water do or just blow-dry it? Or just brush the insides? Thanks
Thanks for replying! I'll keep you guys updated.
