radiator help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2005, 07:19 PM   #1 (permalink)
opp
View opp's Photo Gallery
radiator help!
my car is over heating, ive changed the water pump and the thermostat and filled the radiator back up. the car got hot and i can feel the heat in the top hose but the bottom hose is cold. Does that mean the radiator is blocked?? and needs to be reversed flushed???
opp is offline   Reply With Quote
Old 04-18-2005, 07:37 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273721
View REN69's Photo Gallery
Either that or you need a new rad... are the fins easy to break off or push in???
Old 04-18-2005, 10:04 PM   #3 (permalink)
View cobrajet25's Photo Gallery
You could have scaling and buildup inside your head and blcok, but I would throw a new radiator in first. They are pretty cheap. Regards, Aaron
cobrajet25 is offline   Reply With Quote
Old 04-18-2005, 10:16 PM   #4 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Could mean that you have an air bubble block...Did you Burp your car after filling your radiator back up?(meaning letting the air out after running your car) there should be a bleeder type screw near your gooseneck...It can cause a block just like a solid buildup...If the radiator wasn't blocked before your installation of these items it shouldn't all of a sudden be now...good luck...Radd Guy...
Raddman is offline   Reply With Quote
Old 04-18-2005, 10:20 PM   #5 (permalink)
Registered User
Raddman's Avatar
$100+ Not cheap if your on a budget or going to school and if replacing it didn't solve the problem...Radd Guy...
Old 04-23-2005, 09:24 AM   #6 (permalink)
View fidnee's Photo Gallery
I had/am having the same problem, I flushed the radiator Twice. Car runs the guage in the middle....not overheating, but the top hose is hot, and the bottom is cold. Even though the guage shows normal, the rad overflow is always taking on fluid....back to the bottom hose, should it be cold/hot? i might go with a new rad, beafore a disaster
fidnee is offline   Reply With Quote
Old 04-23-2005, 10:40 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Headgasket most likely, my car did the same.
