86 Corolla FWD Tie Rod - need help
Hi
I just bought an 86 Corolla FWD (I kept getting asked if it is FWD or RWD at all the parts stores). Anyway, I am replacing the passenger side tie rod. I remove the tie rod end from the knuckle.
PROBLEM: I need to remove the tie rod from the rack and pinion. The flat spots are difficult to get a wrench on them, as the exhaust pipe is right under it. It has power steering.
QUESTION: Is there a special tool for this? If not, what do you all recommend? This is the very first import I have owned.
