Front Brake Sounds - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2005, 05:03 AM   #1 (permalink)
Do you wanna have a try??
View michael9413's Photo Gallery
Front Brake Sounds
Damn...
I have a Gen7 1.5 (Japan Engine) Toyota Corolla...
It makes sounds from the front disk brake...
I think that problem is from the pads...
I want to change a new pads any one have some idea what brand is good?
AE-101
1.5 J-Spec Engine
Original Crystal Headlights
michael9413 is offline   Reply With Quote
Old 04-20-2005, 07:59 PM   #2 (permalink)
View karugs's Photo Gallery
What kinds of sounds? If it's squealing, it might just need anti-squeal paste.
karugs is offline   Reply With Quote
Old 04-20-2005, 08:15 PM   #3 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
^^ yea but it also might be his wear indicator too...
BlueFusion6851 is offline   Reply With Quote
Old 04-20-2005, 09:53 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273721
View REN69's Photo Gallery
It may also be the rotors.. mine make a grinding noise when cold. and they squeak when they warm up.
Old 04-20-2005, 09:56 PM   #5 (permalink)
How hard can it be?
ah... the best of both worlds???
Old 04-20-2005, 10:55 PM   #6 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
Originally Posted by michael9413
Damn...
Pull the wheel and inspect it...If you ask a question like "What do you guys think it is" here your going to get 100 different answers, when all you have to do is pull the wheel/wheels and inspect it yourself and find out for sure...You never said what kind of sound ...both sides? one side? just a little squeak? light scraping?..loud metal to metal sound? .Better to catch it sooner then later so it won't ruin the rotor or lock up and get you into an accident.....best pads I have used if you care about the car is Bosch or Bendix ceramic pads$60...If its just a ride then get some cheap store brand semi-metalic pads $15, they work fine...JMHO...Radd Guy
Raddman is offline   Reply With Quote
Old 04-21-2005, 10:01 PM   #7 (permalink)
Thank you for your answers.
My front discs squeaks(quite loud), both of them.
Since i change this it make sounds after a few days.
The pads still new more more than a month my friend.
grinding noise???
I think i hear a little of it when i brake hard from fast pace.
Not everyone can hear that sound.
AE-101
1.5 J-Spec Engine
Old 04-21-2005, 10:15 PM   #8 (permalink)
Registered User
Raddman's Avatar
USA
grinding noise???
If the pads are still new why are you considering changing them as stated in your org. post ...Radd Guy...
Old 04-21-2005, 10:59 PM   #9 (permalink)
KDM is in
REN69's Avatar
If the pads are new.. then probably its the calipers that are sticking.. early sign of seizing calipers.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 04-22-2005, 03:57 AM   #10 (permalink)
well if new pad have this sounds mean that pad is no good...
My brake have to work hard when i'm driving my car...
I always go faster than the speed limit. sometime 2 times of it...
So if the brake is not functioning good better change a new one rather have something unpredictable happen, isn't it....
AE-101
1.5 J-Spec Engine
Old 04-22-2005, 12:02 PM   #11 (permalink)
Registered User
Raddman's Avatar
USA
I really don't think its your pads..Like REN69 said its probably an early sign of seizing calipers...their not backing off...Have your wheels been hot after driving, a burning smell?...If you don't mind spending the money and the time putting in new pads because you think that is the problem then go for it, make sure all the clips are there and put on right and the rotors aren't worn....good luck....Radd Guy
Old 04-22-2005, 09:31 PM   #12 (permalink)
ok thank you for your info.
I'll have a check on that
Cheers
AE-101
1.5 J-Spec Engine
Old 04-23-2005, 02:56 AM   #13 (permalink)
View nadir's Photo Gallery
make sure you have shims + anti-squeel glue in between the back of the pads and the shims.
also, if you put on new pads without resurfacing your rotor, your rotor may be glazed and should be at least sanded down. I've had a major problem with this on my maxima .. i just sorta lived with the problem till i changed both pads and rotors at the same time.
did you break-in your new pads properly? 2 ways .. either babying it or doing 15-20 hard stops from 30-15mph (never actually come to a full stop)...
[ '89 CELICA GT ] ---- [ 5-spd 1996 M A X i M A SE ]
nadir is offline   Reply With Quote
