89 GTS Won't idle after K&N - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2005, 09:26 AM   #1 (permalink)
View browner's Photo Gallery
I have a 89 Corolla GTS with a JDM Bluetop, after installing a K&N cone filter the car would run for 20 second then shut right off. I am using AFM and the stock intake tube. I know this would happen if a air leak is present between the AFM and throtle body but i could not fine one.Please help!!
browner is offline   Reply With Quote
Old 04-22-2005, 07:28 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273721
View REN69's Photo Gallery
post a picture if you can.. I wanna see exactly what and how you did it... I installed mine myself and never had that problem.
Old 04-22-2005, 08:04 PM   #3 (permalink)
View nadir's Photo Gallery
is the AFM plugged in properly?? double check that connection - put the car in test mode and see if it throws you any codes
I would then suggest an airleak, but u have ruled it out ...
retrace your install and make sure u didn't miss to connect something.
[ '89 CELICA GT ] ---- [ 5-spd 1996 M A X i M A SE ]
nadir is offline   Reply With Quote
Old 04-23-2005, 10:08 AM   #4 (permalink)
KDM is in
REN69's Avatar
There's nothing to connect.. that's the problem.. it should've been pretty straight forward..
-unplug the AFM from the airbox
-take out the airbox
-attach filter bracket to AFM
-attach cone/mushroom filter to bracket
That's it.. there were no hoses to attach, the hardest part out of the whole process would have been getting those 2 damn screws inside of the airbox to take them out.. after that it would've been all plug and play. I'm assuming he bypassed something or better yet.. he may have taken out the whole plastic intake with AFM attached to it and then attached one of those ebay intake kits, therefore bypassing the AFM which is a no no. You can't use those metal intakes on 4AGE's with AFM, unless you're attaching the AFM to it.
I'll try finding a picture of my setup, I know I have it somewhere.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 04-23-2005, 01:50 PM   #5 (permalink)
i know when i had to remove my intake many times to get the dizzy out ... one time i forgot to plug in the AFM sensor and the car started but then just died afterwards
Old 04-23-2005, 04:26 PM   #6 (permalink)
Problem fixed!!!! I don't know what the hell was going on, when i installed thd 2nd time all i did different was i did not disconect the battery.Runs good, sounds good, shit it's all good!!
Old 04-23-2005, 09:45 PM   #7 (permalink)
View corollasr5's Photo Gallery
I didnt have any problem putting mine on, thats fro sure.
i recently have had a problem with my 4age though, i put an aftermarket header on, when i got it all put back together it surged, it is still surging today. it revs from 1 to 1.5 rpms then back to 1, its really weird. any ideas?
corollasr5 is offline   Reply With Quote
