fuel problem with my 20 v 4age - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2005, 01:02 AM   #1 (permalink)
View rcmathis's Photo Gallery
AE92 fuel problem with my 20 v 4age
was wondering if any one could help me fix my fuel problem or if it is a fuel problem. no low end power and top end wants to cut out. dont want to get rid of my baby but is pushing my last button. also if where i could find parts in the states for my motor?
rcmathis is offline   Reply With Quote
Old 04-23-2005, 04:39 PM   #2 (permalink)
View RakeRon's Photo Gallery
Closet place to find parts would probly be in Cali, otherwise you might have to see if a dealer would import the stuff you need. Now a little more info about your swap would help. Like did you do the swap yourself? Was it running fine after the swap? Did you do the blacktop ECU swap? Does it use the stock ecu? etc.
RakeRon is offline   Reply With Quote
Old 04-24-2005, 02:17 AM   #3 (permalink)
did all the work with a friend. ran fine once it was in just not now. got a hole front half of car for a killer deal of 1500 cash. it is a silver top with its own ecu dont think stock will work. run high octane gas in it when you are done. you might have to cut harness in car in front of shifter to make work could always try your own dont know if it will work. do you know why the car is sputtering by any chance. I think it is injection prob my self. let me know about your swap
Old 04-24-2005, 10:30 AM   #4 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
check your fuel filter, fuel pump, and fuel lines.
might want to check your dizzy, high tension wires and plugs as well.
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 04-24-2005, 10:57 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Might be on limp home mode....
