cam removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2005, 03:14 PM   #1 (permalink)
View stealthtt24's Photo Gallery
cam removal
searched, found nothing. anyone know of any websites/tips for cam removal?
stealthtt24 is offline   Reply With Quote
Old 04-28-2005, 04:28 PM   #2 (permalink)
Gameroom cash: $121755
um, what motor?
1) 1990 Corolla "SR5", part silvia, 7age.... & more 2) 1986 MR2, "MK1.22" 91 5SFE/S54 swap 3) 2010 Corolla S 5-speed (the super nice/low mileage DD - wife) 4) 1998 Camry (the boring, high mileage DD - me)
Old 04-28-2005, 04:29 PM   #3 (permalink)
88 corolla, sr5, so 4af?
Old 04-28-2005, 04:34 PM   #4 (permalink)
it's gonna be tricky to remove the cams..... why do you need to remove them?
first pull the valve cover and timing belt covers off
turn the crank until the 2 dots on the gears on each of the cams are pointing towards one another (you will know what i'm talking about when you pull the cam cover)
remove the timing belt...... remove the timing belt cam pulley (there is only one).... make note of where the cams are positioned.... then start unbolting the "arches" that hold the cams in.... be careful to note which ones came from where (they *should* already be stamped with I1, I2, I3, I4, and E1, E2, E3, E4, but you should still lay them down in order as they came off) and make sure the respective bearings go with where they came off....... the cams should be removeable now
Old 04-28-2005, 08:34 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
why are you doing this?
Old 04-30-2005, 04:40 PM   #6 (permalink)
my car is making a funny noise after being on the highway, its like a loud ticking from the top of the motor... my friend thinks something has happened under the cams
Old 04-30-2005, 07:52 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
its probably the gears that drive the other cam that is under the valve cover, one of the gears is split in half down the gear teeth and the other half is under spring tension to get rid of gear clatter, see if anything is wrong with the gears and turn the motor over by hand with the cover off to see if the gears knock against each other, take the plugs out and this will be much easier to do
Old 05-03-2005, 10:46 AM   #8 (permalink)
ok cuz i want to do this myself.... it only makes this noise right on startup for a second (cold mind you) then when the car is fully warmed up.... then it makes it a good 90% of the time. any more help?
Old 05-03-2005, 06:32 PM   #9 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
ya think its a rod knock?
