Drive Shaft Bolt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2005, 11:48 PM   #1 (permalink)
Toyota Addict
briangk_77's Avatar
View briangk_77's Photo Gallery
Drive Shaft Bolt
The manual for 05 Corolla and Matrix advises to "tighten drive shaft bolt" at least every 15,000 miles. Does anyone know about this? I would appreciate it if someone could share a picture or description. Also, I would like to know the appropriate torque of the bolt.
briangk_77 is offline   Reply With Quote
Old 06-06-2005, 02:01 PM   #2 (permalink)
TN member
View Mins's Photo Gallery
Anyone??
'05 Corolla LE Silver Streak Mica
Mins is offline   Reply With Quote
Old 06-07-2005, 03:43 PM   #3 (permalink)
View mburger's Photo Gallery
I have the 2005 maintenance manuals for the corolla and and the only bolts I see on the drive shafts ( front axles) are the lugs. So my guess would be to check the lug nuts for proper torque. The right and left drive shaft are the front axles... Someone correct me if I'm wrong.
mburger is offline   Reply With Quote
Old 06-08-2005, 08:33 PM   #4 (permalink)
Toyota Addict
briangk_77's Avatar
I'm thinking it is not the lugs...
For 2WD models, my maintenance guide book says to retorque drive shaft bolt...for 4WD models it says drive shaft bolts. So, I am sure it has to do with the drivetrain, just don't know where the bugger is on the Rolla or what torque is appropriate.
Old 06-19-2005, 02:32 PM   #5 (permalink)
View jjsagain's Photo Gallery
I too have just purchased a 05 corolla S and read the same thing about the drive shaft bolt and was looking to ask this very same question here. They do make it sound like it is important that it is retorqued often.
jjsagain is offline   Reply With Quote
Old 09-05-2005, 05:19 PM   #6 (permalink)
often.
Were is the drive shaft bolt?
Old 09-06-2005, 04:05 PM   #7 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
I thought 4WD and RWD vehicles only had driveshafts.
SR5_4WD is offline   Reply With Quote
Old 09-06-2005, 08:36 PM   #8 (permalink)
View 89molavi's Photo Gallery
Isn't this the same big Hex nut in the center of the front wheel holding the axle. I have never torqued it though, but then I had an 89, gone now!
89molavi is offline   Reply With Quote
Old 09-07-2005, 02:25 AM   #9 (permalink)
RedAE102's Avatar
View RedAE102's Photo Gallery
It's the huge (30 mm I think) nut on the end of both front driveaxles (rears as well on RWD cars)... 159 lb-ft is spec on '93-'97 cars, 166 lb-ft on '98-'02, so use your best judgement or buy a manual. Until the passenger side inboard CV boot blew apart at 130,000 miles, the hub nut on either side had not been checked on my '93 in its entire life.
'93 Corolla AE102 XLi saloon
We're all looking for something.... Something to be...
RedAE102 is offline   Reply With Quote
