1998 corolla is bogging, misfiring, hesitating "big time!!!!" could it be that.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2005, 11:49 AM   #1 (permalink)
View 98inthe818's Photo Gallery
USA 1998 corolla is bogging, misfiring, hesitating "big time!!!!" could it be that....
when i replaced the spark plugs, they weren't the stock/factory plugs? should i go to the dealer and get 'em? it just seems to be getting worse everyday .....
thanks!!
98inthe818 is offline   Reply With Quote
Old 04-30-2005, 12:49 PM   #2 (permalink)
Gameroom cash: $134355
did you replace the wires as well? possibly split one of the wires when you changed the plugs
Old 04-30-2005, 01:06 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
or maybe you got the wires put on wrong ;P
Old 04-30-2005, 01:13 PM   #4 (permalink)
yup, i replaced the wires and i did put them back where they belong
Old 04-30-2005, 01:29 PM   #5 (permalink)
i also just checked for vacuum leaks and all the hoses looked fine. when i'm at a stop and i step on the gas to go is when i feel it the most. it sputters and then sometimes it makes a "popping", sound. like it's gasping for air.
Old 05-01-2005, 02:28 PM   #6 (permalink)
View BALIKBAYAN's Photo Gallery
Have you checked the isolation on the spark plugs? I had 2 plugs with cracks and the car didn't like that very much. It didn't run an all cylinders and it was terrible to drive.
If you have a crack in the isolation there will be no good ignition. The current will take the easiest way back to the battery, through the crack in the isolation and the engine block.
BALIKBAYAN is offline   Reply With Quote
