Wiil disconnecting the battery reset the CPU? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2005, 10:04 AM   #1 (permalink)
View jasontoy's Photo Gallery
thanx...jason toy
jasontoy is offline   Reply With Quote
Old 05-01-2005, 10:07 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
To an extent, yes. I read somewhere that if you turn the ignition to 'on' with battery off it resets faster, can't say for sure on that but it makes sence.
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 05-01-2005, 10:17 AM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Yes. If you cut the power to the ECU for more than a split second it resets.
Instead of pulling the battery, pull the EFI fuse. It's a bunch easier, and you don't loose clock, and radio presets.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 05-01-2005, 11:03 AM   #4 (permalink)
View NDR008's Photo Gallery
take out the efi fuse, but i am not sure regarding the time, so just leave it for some minutes anyway - guess its like motherboards - some keep the bios settings for 30seconds without a battery, some are designed to keep it even for 2hours without a battery.
You shouldn’t drive for the thrill, but for the pleasure of tasting the control…
NDR008 is offline   Reply With Quote
Old 05-01-2005, 11:20 AM   #5 (permalink)
Toysrme's Avatar
Cool
Ya it's nearly instantly.
I've cleared a billion codes on mine. As quick as you can take it out, turn around and put it back in it'll reset codes, and clear stored data.
No need for that "5 min" "10 min" "or hours.overnight" bullcrap. That's a waste of time
Now with Turbo!
Old 05-01-2005, 01:19 PM   #6 (permalink)
Thank you for the replies, have a nice day.
toy
Old 05-02-2005, 06:40 AM   #7 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
If you go with disconnecting the battery, DO NOT do it with the ignition key in the on possition.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
