89 gts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2005, 01:54 PM   #1 (permalink)
View 89TCGTS's Photo Gallery
AE92 89 gts
I have an 89 corolla gts and i just changed the cv joints. When i changed them some gear oil came out. I was wondering where do you check that at.......or where do you fill it.....I'm guessing it has a fill plug somewhere but i don't know where. I have a book for my car but it only has stuff about an automatic transmission, and i have a manual.....Please Help!!!
89TCGTS is offline   Reply With Quote
Old 05-01-2005, 04:27 PM   #2 (permalink)
View bob022004's Photo Gallery
the drain plug is down low on the differential. the fill plug is up on the transmission facing forwards. just remove the fill plug and fill with gear oil until it reaches the bottom of the fill plug hole. both plugs requre a 24mm wrench.
1988 Toyota Corolla GT-S
16V 4A-GE
ACT Stage 1 clutch
bob022004 is offline   Reply With Quote
Old 05-01-2005, 05:52 PM   #3 (permalink)
I already found it so thanks anyway for the help......I needed to know quick and i ended up just looking for it and found it so thanks.
Old 05-02-2005, 06:08 PM   #4 (permalink)
no problem. sorry i wasn't faster. just did a clutch swap on mine so i learned a few things. like the thermostat is nowhere near the block. and that the clutch master is a real PITA to swap out. and the clutch lines don't lend themselves easily to bleeding out air bubbles. too many sharp turns trap them up pretty bad. but i do love this ACT stage 1 clutch.
16V 4A-GE
ACT Stage 1 clutch
