Coolant issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2005, 10:06 AM   #1 (permalink)
View BCbear's Photo Gallery
Canada Coolant issue
It appears I may have a leak in my coolant system and I was wanting some guidance on the issue.
I used my defogger recently and when I moved the temp slider the window began to fog up quickly. At first I thought my visabilty was as result of steam coming from under my hood. I pulled over and lifted the hood but nothing appeared wrong. My windshield had this film on it and the car had a hint of sweetness to it. It reminded me of that fog machine fluid, which I know is comprised of glycol (?). I checked my rad fluid and it was a little over the top of the core.
Do you figure there is a leak in the piping that travels through the firewall to the heater? Anyone else had this problem and can direct me to a resolution. I have moderate mechanical skills and tools.
Many thanks.
BCbear is offline   Reply With Quote
Old 05-04-2005, 10:14 AM   #2 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
Many thanks.
This "film" was on the inside of your windshield, if I understand correctly ??? If so, sounds like maybe the heater core is leaking....had that problem many years ago with an old Buick, that's what it was - same symptom....."film" on glass from coolant.. That'd be my (un)educated guess...heh...how old is your car ???
PhantomS is offline   Reply With Quote
Old 05-04-2005, 10:19 AM   #3 (permalink)
ems
View ems's Photo Gallery
Your heater core is probably leaking.
ems is offline   Reply With Quote
Old 05-04-2005, 11:19 PM   #4 (permalink)
My car is a 1989 (base model)
Is the heater core easy to replace? Do you usually replace the whole unit or is a part within the core?
Thanks
Old 05-04-2005, 11:35 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Most cars require a disassembly of the dash. I'd highly recommend taking that to a shop.
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
