Oil Requirements - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2005, 08:07 AM   #1 (permalink)
5AFE_AE100_92's Avatar
View 5AFE_AE100_92's Photo Gallery
Question Oil Requirements
hey.. how much oil does a 5afe require... i changed my oil and out in 1 gallon checked it a few days after and it read below half.....
when i start the car the oil light stays on for about a second
should i put in more or am i burning oil some how.. someone told be they saw smoke from the muffler when i moved off
5AFE_AE100_92 is offline   Reply With Quote
Old 05-09-2005, 07:42 PM   #2 (permalink)
View 03mooncorolla's Photo Gallery
Did you change the filter when you changed the oil?
If so when you filled the engine with oil did you start the vehicle for a few seconds to fill the filter,and the recheck the level.
That may be the reason for it reading low on the stick a few days later.
The oil light staying for second should be normal, I do not know how much oil a 5afe requires I'm not the one to answer that for you .
I hope the above statement helps you out.
03mooncorolla is offline   Reply With Quote
Old 05-09-2005, 09:00 PM   #3 (permalink)
yesi also changed the filter
Old 05-10-2005, 01:48 AM   #4 (permalink)
Do you wanna have a try??
View michael9413's Photo Gallery
maybe your engine is not good already..
the pistons are a bit lossen compare with the new one..
the white smoke from the exhaust... is the smoke exist if your engine running idle?
Is yes please overhaule your engine...
I face this problem also...
After every service half of my engine oil will be gone by a month time.
So the mechanic advise me to have it overhaule..
after that it doesn't exist anymore...
AE-101
1.5 J-Spec Engine
Original Crystal Headlights
michael9413 is offline   Reply With Quote
