what's wrong? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2005, 12:25 AM   #1 (permalink)
View LoneWolfKenshin's Photo Gallery
what's wrong?
If my
tachometer, trip meter, oil level meter, water temperature gauge, fuel level gauge, backlight
don't work, BUT my
speedometer and odometer
do work...
and all the fuses are fine...
What should I check or replace in order for them to work?
(1986 SR5 coupe...bone stock 4AC)
LoneWolfKenshin is offline   Reply With Quote
Old 05-10-2005, 01:12 AM   #2 (permalink)
View karugs's Photo Gallery
Check your fuses again...
Speedo and odo are usually mechanical so they don't run off a fuse. Not sure about trip meter though...
karugs is offline   Reply With Quote
Old 05-10-2005, 01:50 AM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273721
View REN69's Photo Gallery
The trip meter runs off the odometer, which runs off the speedometer.. so yeah they run off the speedo cable which is mechanical. There's a fuse for all the other stuff, if the fuse is fine, you might have a bad wire somewhere.
Old 05-16-2005, 09:50 PM   #4 (permalink)
re-read what i typed, i said the odo and spedo WORK. I want to know what's wrong with the other stuff.
Old 05-17-2005, 01:53 AM   #5 (permalink)
KDM is in
REN69's Avatar
you re-read fool!! I told you they work because they're mechanical.. the other stuff don't work because there's a fuse or relay that's probably blown.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 05-17-2005, 02:01 AM   #6 (permalink)
His fuse is probably blown
Old 05-23-2005, 12:54 AM   #7 (permalink)
any idea where the fuses you speak of are? i checked the kick panel on driver side and the fuses in the engine bay...if there are more, i have no idea where they are located. if it's wiring, where can i buy the wiring and possibly get it installed if it's too hard for a noob like me to do?
