Lowering Springs Wanted for 94 rolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2005, 10:50 AM   #1 (permalink)
View ris77's Photo Gallery
Hey.
IM new to the forum. Im looking for lowering spings for the rolla. I guess more so the H&R drop of 1.25" anyone have any for sale, or a canadian supplier of the springs?
let me know.
FYI - The 99 rear shock/spring assembly fits in the 93-97 rolla.
r.
ris77 is offline   Reply With Quote
Old 05-11-2005, 01:16 PM   #2 (permalink)
View lifeisviewtiful's Photo Gallery
aerospeed i hear makes good springs to sit on some performance shocks. try some coilovers if you want. my car is lowered but in the front my right is slightly higher than i my left front(a common problem with 93-97 models from what i heard)also watch out for tha exhaust piping right before it curves into the flange for the muffler. in like every single toyota i seen camry, corolla whatever the pipe hangs down and scrapes when going over speed bumps.
lifeisviewtiful is offline   Reply With Quote
Old 05-11-2005, 02:38 PM   #3 (permalink)
View sonyminidiscman's Photo Gallery
i got a set of tokico blues and eibach pro kit.........
will be availiable in about 3 weeks.
94 corolla
http://www.cardomain.com/id/sonyminidiscman
sonyminidiscman is offline   Reply With Quote
Old 05-11-2005, 04:41 PM   #4 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $114450
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Do a serach ... there are quite a few options for the gen7 (93-97)
I have coilovers and they rock I also had Espilers for a while which were good too.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 05-11-2005, 10:09 PM   #5 (permalink)
if u want the set... pm me
94 corolla
Old 05-12-2005, 11:39 AM   #6 (permalink)
Hey,
Thank you for all your input; in my case, im going just looks. so ill be just looking for just lowering springs on stock shocks.
Old 05-12-2005, 12:43 PM   #7 (permalink)
Then you better be prepared to pay for new struts later. Because your oem struts are 10 years old and after lowering it, it will wear out even faster.
94 corolla
Old 05-13-2005, 10:41 AM   #8 (permalink)
Yeah i realize the OEM struts are oil not gas. Has anyone felt the difference between the oil and gas feel.
Old 05-13-2005, 11:03 AM   #9 (permalink)
well... after lowering your vehicle, your oem struts will sit much lower than its suppose to... and you will bottom out your struts more often. and since lowering springs generally have higher spring rates and if you struts does not provide enough dampening, you car will bounce around and make it dangerous to drive, especially at high speeds and cornering.
94 corolla
Old 05-13-2005, 11:32 AM   #10 (permalink)
yah he's right. i got some decent struts for my application and i can definitely tell the difference in stock and performance. if you are going to lower on stock struts i strongly suggest at least buyin new oem struts(especially in the rear) and ride on them until you save enough for some performance set especially in the rear. i rode on stocks for quite a while but then again i don't carry much people in my car . sony is right tho the stock struts are not meant to handle the high spring rate and you have to understand as well that you struts when lowered are compressed ALL the time which is what will wear them out to rapidly because they were not designed for such an application.
i highly recommend AT LEAST replacing the rear ones before lowering ESPECIALLY if you get coilovers.
Old 05-13-2005, 11:34 AM   #11 (permalink)
also whatever you do. DO NOT BUY CHEAP EBAY COILOVERS/SPRINGS
Old 05-13-2005, 11:57 AM   #12 (permalink)
i don't even know how much oem struts are...
but i doubt that they are cheap... man, last time I wanted to buy a fog light switch from dealers, they told it its 80 bucks... for a stupid switch!
if you want my set of struts, i will sell for 450 and if you want the eibach spings, 100
94 corolla
Old 05-13-2005, 09:10 PM   #13 (permalink)
Well I have already replaced my rear struts and springs with a pair off of a 1999 Corolla. They fit right in place, this is after the fact that the idiotic Toyota dealer told me they are different and gave me the wrong paint code...they are extremely smart. I picked up the entire assembly for the rear for $100. used of course.
And now ive gotta change the front end. I just pick up those for $150 (99 rolla parts) for both the spring, strut, ball joints, calipers, and disks... well we shall see if those fit.
Old 05-14-2005, 08:49 AM   #14 (permalink)
Guest
View pb_will's Photo Gallery
Hey Sony,
R u selling those Tokico blues and eiback brand new or used?
pb_will is offline   Reply With Quote
