You may have to reinstall.
You should make sure all the marks are lined up, or a timing gun wont help. You may have to reinstall the belt. There are 2 mrks on the end of the cams that must be in line with the marks on the inner guard. Same with the crank, there is a mark on the lower gear that lines with the mark on the inner lower cover. did he leave the belt covers off? If so you can check without too much hassle. I just went through this process so ask if you have Q's.
There are those who do things, and those who take credit... The trick is to be in the first group, there is a lot less compitition.
