acceleration/shifting problems
I have a 00 Corolla with a PO300 code, which is random engine misfire, I believe. The engine reacts very slowly when opening the throttle. If I step on the gas quickly, the engine chokes for a second before finally revving up. I can't even floor it though cuz it will just choke. This is the first problem...
The transmission also takes real long to shift to the next gear. I don't know if this problem is related to the engine problem, but it seems like it takes forever for the transmission to select the next gear unless I get off the gas.
Anyone have these problems, and how did you fix them?
Thanks
