sry for the many 20v q's for my just finishing ae86 project, but i like to do it all as well as possible = well researched
I need to make/adapt/buy a throttle cable from my sr5 to the 20v. Today i got the idea of cutting the cable, and doing an extension so i get to use the original bracket that holts the cable
i have enough cable (full stock and ~ 1.5ft of the 20v's) and i'd need 2 brackets (WHICH, HOW??) to do the extending and then i'll have a good setup...Question is, is there a specific car whose throttle cable is long enough and will bolt to the things in my firewall (by pedal)
or simply phrased, which throttle cable to use
Thanks TN...
as payback for all your help i'll do a huge wiretup from A-Z, parts needed, wiring to be dune, Things to adapt and all the usual which i now know by memory.
"Charles Xavier, from X-MAN tried reading Jack Bauer's mind once and now he's on a wheelchair"
99 A 3.2TL Nav | 88 332is [rip] | 88 332is ; ]
86 Ae86 20v, trd susp&lsd [sold]
Don't try to cut and extend. Not worth the trouble. The non-cruise control GTS ones will work just fine. You can also get a Toyota Tercel one from the early 90's. Those are long enough to modify and fit. You will need to remove a small piece so you have enough slack at the end, but those will work. I believe the non-cruise control 22RE truck/celica ones will work also.
__________________ It's ok to be naked, girl... I'm an Artist!
great info!! even though the cutting is not trouble, i can actually weld the cables together with a maap-oxy torch i have
Keep the info coming...i'm just worried about the little plastic piece by the firewall above the pedal that bolts the cable to the firewall (two screws u know...)
personally i would not extened it now thats just ghetto.lol
do it the right way the first time and you will be ok did you check e-bay for throttel cables?
yeah i looked for throttle cables on ebay and i dont find a suitable one...wondering if the throttle cable has another name
my car's almost wired up and ready to start so i'll need this asap omg!! and i'll also need a downpipe from the ae86 gts so i dont run exhaust straight out of the headers and onto my slave cyl....HELP!!!
haha...any other cars i should consider taking this cable from?
i'm planning on going to a u-pull-it junkyard tomorow after a macroeconomics test... hopefully i'll find something that works from there...as well as a twin cam '86 to take the downpipe, gearbox, driveshaft and rear end off off
Keep in touch mr.godfather
