Fuel filter, lean system, check engine light
Hi all - I'm new here and have a couple of questions.
I have a 2001 Corolla S with 65K miles and the check engine light is on. Had the code read and it shows that the system is running lean. When I step on the gas - the engine bogs down before going anywhere. I replaced spark plugs last night - did not help. I wanted to replace the fuel filter (don't think it has ever been replaced) - could you tell me where it is located or if there is a DIY on how to do it. I wanted to replace all the simple inexpensive stuff first before i start messing with the O2 sensors.
Any other suggestions on what it can be?
Thanks!
