Bottoming out? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-20-2005, 10:06 AM   #1 (permalink)
View awdark's Photo Gallery
AE92 Bottoming out?
I'm not sure if this is what bottoming out is considered.. but whenever there is any major+fast weight transition such as during hard braking or sharp turning, it goes "bang" and feels likes like the springs completely compressed and let the chassis slam into something and it handles like crap.
Totally stock, original 175/45/13 or something tires, not dropped. The suspension seems fine in that if I run over something, it only bounces once and stabilizes after the rebound but I'll pay more attention to that today.
awdark is offline   Reply With Quote
Old 05-20-2005, 11:48 AM   #2 (permalink)
Yes, I can drift!
88CorollaFX's Avatar
View 88CorollaFX's Photo Gallery
I have the same thing happen with my AE82 FX on a regular basis. It's the shocks. Change the shocks out, and you should be aight. I figured that because it wasn't that harsh over speed bumps and stuff that it couldn't be the shocks, but the extreme roll in the car causing the car to scrape or bottom out on even the front of the car during turning means that the shocks are gone. Change the shocks and you should be good.
1988 AE82 Corolla FX: 107 hp, 35 mpg, 2300 lbs. How can you go wrong? FS, $1000 or best offer.
1989 S13 Nissan 240SX: My favorite toy, and newest addition to my garage.
1977 S30 Cali Edition Datsun 280Z: For Sale, $4500 Or Best Offer.
88CorollaFX is offline   Reply With Quote
Old 05-21-2005, 04:54 PM   #3 (permalink)
View bob022004's Photo Gallery
Mine's pretty bad about it too. struts are toasted. nothing left in 'em. just gotta watch the bumps until you can swap 'em out or you're gonna really crack an upper strut mount.
1988 Toyota Corolla GT-S
16V 4A-GE
ACT Stage 1 clutch
bob022004 is offline   Reply With Quote
Old 05-21-2005, 06:20 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Look for any oil or grease residue on the shock itself.. that could mean they're done for.. if they're gas charged, the only way to tell would be the bounce test.
Old 05-23-2005, 04:28 PM   #5 (permalink)
View 89TCGTS's Photo Gallery
it might be your tires hitting the wheel well......i don't know if you have big tires but i know on my brothers old 91 ford probe when he had more than 3 people in it his tires would hit the wheel wells, and it would sound like a "bang"
89TCGTS is offline   Reply With Quote
Old 05-24-2005, 02:49 AM   #6 (permalink)
View karugs's Photo Gallery
Many factors may affect this. One will certainly be consistent. But if you drive the car wildly, if you take corners like a madman, if you are of medium to heavy build in this Corolla, then chances are the effects are amplified. If your car bounces like a loose spring when you put weight on one corner of the car, then the shocks are going bad. Usually they should just bounce once or twice at most and the car should go back to its original level.
These cars have thin anti-sway bars and not much anti-dive properties.
By the way, bottoming out is when the lowest point of the car hits the ground upon rebound of the car when going over bumps. Imagine you're using that same car while going over a speed bump, at 40mph...
Drive safe!
karugs is offline   Reply With Quote
Old 02-14-2010, 07:17 PM   #7 (permalink)
View sunny1975's Photo Gallery
Bottoming out
Hi
I am totally non-technical and got robbed by mechanics and I desperately need some help. I have very serious problem here. I bought a 2000 corolla CE a month ago. My car has a bottoming out problem. I hear a knocking sound front underneath the car when I hit a pothole or uneven road (you can find plenty in chicago). sound is louder on driverside than passenger side. I took it to Meinke and they said car needs new strut mounts ( I already have changed both front struts, coil springs and spring seats). both strut mount look good, no wear or tear. Do you guys think, I really need strut mounts or there is any other problem. It seems that shocks(struts assembly) are not long enough to keep the car on suspensions or there is very little clearance and when car hits a pothole then bottom part that connects two wheels (I dont the exact name) hits chesis. I dont want to go to dealer coz they will charge me $2000 for a car that is only worth of $3000. Any help/suggestion would be appreciated
sunny1975 is offline   Reply With Quote
