newb - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2002, 11:46 AM   #1 (permalink)
Shit Disturber
View hopeful's Photo Gallery
newb
Me: person in Toronto
Mines: nuthin yet... thinkin bout the ae86
Mods: my computer has more ram now...
that thing above is embarrasing but you gotta play by the rules... Well anywas i might as well put up a question with this...are 1987 Toyota Corrolas also considered ae86's? And when did they go FWD? thanks
There is no purpose to a life which does not search out its purpose, look for god and you shall find Him. Know what you feel of the oneness of god within you is no coincidence, and know that no coincidence is without purpose.
hopeful is offline   Reply With Quote
Old 08-21-2002, 11:49 AM   #2 (permalink)
operation boro thunder
View project trueno's Photo Gallery
welcome
1985-1987 Corolla GT-S are AE86s, RWD
1988-1992 Corolla GT-S are AE92s, FWD
so just a 1987 corolla will not be a AE86
and you're supposed to give your NAME in the "ME" part...
project trueno is offline   Reply With Quote
Old 08-21-2002, 11:52 AM   #3 (permalink)
Shit Disturber
oh my bad... Arif Mandozai... If it means anythin...I was wonderin why nobody jumped on this little kitty..thanks for your reply http://www.trader.ca/Search/Enlarged...=768&CAT=1
Old 08-21-2002, 12:19 PM   #4 (permalink)
Banned
View goodcookiedrift's Photo Gallery
why? cuz you can see the rust in a 72 dpi picture thats about 300 x 300 pixels. that in itself should be an indicator to stay away.
Nick
goodcookiedrift is offline   Reply With Quote
Old 08-21-2002, 06:11 PM   #5 (permalink)
Shit Disturber
Is there a way to tell if the car is a GTS by the look of it?
rust isnt too hard to fix...
Old 08-21-2002, 06:17 PM   #6 (permalink)
View fatredcircle's Photo Gallery
rust isn't hard to fix?
lol
if you send it to an autobody shop and give them alotta money it isn't hard
but doing it yourself?
heh
right
it ain't hard at all :roll:
fatredcircle is offline   Reply With Quote
Old 08-21-2002, 06:30 PM   #7 (permalink)
Shit Disturber
I havent fixed rust myself so i cant tell you anything more about it... I didn't think it was.. oh well so are there any physical differences between a GTS and like non GTS lol... Other than searching for a driveshaft...
Old 08-21-2002, 07:17 PM   #8 (permalink)
Resident Wrench Monkey
ek-9's Avatar
View ek-9's Photo Gallery
welcome newb,
lift the hood and look for 2 cams. done.
and what you you be looking for on the driveShaft (curious)?
ek-9 is offline   Reply With Quote
Old 08-21-2002, 07:48 PM   #9 (permalink)
Shit Disturber
oh i thought ONLY the GTS model was RWD... I was wonderin.... how the hell did they afford that.... can someone give me a link to something like a swap guide... like i've got tons of questions that are probably just going to piss u off.....
Old 08-21-2002, 08:01 PM   #10 (permalink)
View Twincam16's Photo Gallery
You can start with www.club4ag.com
Good Luck.
Norm
Twincam16 is offline   Reply With Quote
Old 08-21-2002, 10:08 PM   #11 (permalink)
View mr_sinister's Photo Gallery
the basic gist of it is that its usually not worth doing an sr5->gt-s conversion becasuse you need an entire donor gt-s anyway.. plus all the work it will take..
also rust is VERY expensive to fix if you want it done right.. if you do a half ass job, then its cheap, but it will come back in no time..
mr sinister
1987 ae86 - black hatch
--- GTP Light Tune SPL Super Lace Edition
2001 VW GTI 1.8T
--- "Racing" pedals.
my website
mr_sinister is offline   Reply With Quote
Old 08-21-2002, 11:07 PM   #12 (permalink)
Shit Disturber
the half assed way being using bondo and fiberglass?
And what are the differences in GTS and the normal model?
is it only tat the GTS came twin cam? and if i wanted to do a 20 valve swap would it make sense to not get the GTS?
Old 08-21-2002, 11:17 PM   #13 (permalink)
Banned
you should put a 20v in a sr5. thats the best bang for the buck...and it will be faster than a stock ae86. thats the way for sure.
Nick
Old 08-21-2002, 11:32 PM   #14 (permalink)
1nzfe addict
View toymaniac's Photo Gallery
first both gts and sr5 have twin cam engines in the gts its a 4age and in the sr5 its a 4af the four doors model had the 4ac single cam
gts 4age +/-120-128hp rwd fuel injected
sr5 4af +/-100hp rwd caburated
4 doors 4ac +/-80 hp front wheel drive carburated
in any case you want to put a 4agze or 3sgte or any other motor in it
you should always have a gts to begin whit...
cuze all the suspension the transmision differantiel even brakes are not the same
even the gas tank is not the same fuel injected models have a electric fuel pump in the tank
and the carburated models 4af and 4ac have a mecanical fuel pump on the engine
the 4age (gts)was built for power over economie
the 4ac and 4af were built for economie
like i said in the begining
both 4af and 4age are twin cams
but the the 4age is reconisable by the wider valve cover that you can clearly see that it as 2 cams
the 4af in the other hand does not show that it as 2 cams
the other egine (4ac)is a sohc (single over head cam) you guess it only 1 cam and 8 valves insted of 16 for twin cams or 20 for the 20v
hope this helps you a bit need help to clarify things
any other questions e-mail me
sgoyer@videotron.ca
ciao
Toymaniac ADM. ClubEchoQuebec.com
toymaniac is offline   Reply With Quote
Old 08-21-2002, 11:54 PM   #15 (permalink)
toymaniac above is talking about an AE92
ok its like this...
AE86 (RWD) 1985-1987
GT-S uses 4age, DOHC, 112hp@6600, redlines at 7500
SR5 (also RWD) uses 4ac, SOHC, around 80ish hp....
normal 4-dr corolla uses 4ac, NOT RWD
AE92 (FWD) 1988-1992
1988-1989 GT-S uses 4age, DOHC, 112hp@6600
1990-1992 GT-S uses high compression 4age (red top), DOHC, 130hp
1988-1989 SR5 uses 4af, DOHC, 102hp
1990-1992 SR5 uses 4afe, DOHC, 102hp
the 112hp 4age is called "blue top", since it has blue lettering on top of engine, it is also refered to as "low-comp"
the 130hp 4age is called "red top", since it has red lettering on top of engine, it is refered to as "high-comp"
for more info on blue and red top goto club4ag.com, reference section
