From what i understand, the headers will not work. The dfference between a 4AFE and GE is only the head, not the block. Because the headers come off the head, they arent interchangable. Most of the Peripherals (A/C, Power steering pump, Alternator) however should be. Gearboxes will be interchangable and some of the stuff like radiators and water pumps will be. You also have to think (when thinking interchangibility) is things like metering systems and ignition systems. On the FE's from 93 on for example, the dizzy has a built in coil, the GE's do not. The FE's in this period are MAP metered whilst the GE's (20v Silvertop specifically) are AFM metered.
Someone may want to correct me if i'm wrong about the metering and ignition systems. But in answer to your question, there are alot of parts that are interchangable, but there are also alot that are not.
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
