'03 Corolla headlight adjustment? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2005, 02:59 AM   #1 (permalink)
View startac205's Photo Gallery
Hello all,
I know a lot of cars have the "adjustment screw" that let you adjust up/down of the headlight.
Does '03 Corolla S has it? I couldn't find it...
If there is no screw, is there any other way I can adjust the headlight?
Any info is greatly appreciat.
Thanks
'03 Corolla S
'97 Camry LE
startac205 is offline   Reply With Quote
Old 06-01-2005, 03:23 AM   #2 (permalink)
Do you wanna have a try??
View michael9413's Photo Gallery
Well i have a pair of the clear head lamps on the AE 101...
The adjustment screw is hide behind of the lamps...
Try to peek at the back...
It used a spanner or nut adjuster to adjust it
AE-101
1.5 J-Spec Engine
Original Crystal Headlights
michael9413 is offline   Reply With Quote
Old 06-01-2005, 06:19 AM   #3 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
the screw is there....when I took mine out was the 1st time i noticed them. passenger side is easier to get at
adsaba1969 is offline   Reply With Quote
Old 06-01-2005, 04:01 PM   #4 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Originally Posted by startac205
Hello all,
Thanks
It has an adjustment screw on the back of the light...passenger side looking at the back of the light its at 7 o'clock with 12 volts printed above it...I thought mine were out of adjustment because looking at the road at night the drivers side had a shorter beam then the other side and the service guy said it was set that way so the passenger side shines farther but the drivers side doesn't blind other drivers...good luck...Radd Guy...
Raddman is offline   Reply With Quote
Old 06-01-2005, 08:56 PM   #5 (permalink)
thanks a lot for the info! =)
'03 Corolla S
'97 Camry LE
