My wheel bearing or not? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2005, 11:43 PM   #1 (permalink)
View Ghost's Photo Gallery
i have a 2000 corolla.......my question is it is normal for the frony hubs.....on both sides to get really hot......eg hot to the touch.....i don't have any noises, but the ride is rather harsh and not that smooth anymore?.....don't think its my rotors either......no shimmy when breaking?
Ghost is offline   Reply With Quote
Old 06-03-2005, 03:03 AM   #2 (permalink)
Do you wanna have a try??
View michael9413's Photo Gallery
Please that is cause by the hot air from the DISC brake that you are using it during braking... The disc is so so so hot until can fry some eggs
AE-101
1.5 J-Spec Engine
Original Crystal Headlights
michael9413 is offline   Reply With Quote
Old 06-03-2005, 11:06 AM   #3 (permalink)
so than why would my steel rim be so so hot that you can burn yourself on?
Old 06-03-2005, 11:21 AM   #4 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $113950
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
yup it all gets hot with normal use. When your bearings go bad you'll be able to wiggle the hub in the spindle and when they get really bad you'll see lines or grooves in your rotor from the pad.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 06-03-2005, 11:58 PM   #5 (permalink)
Really... hmmmm.... learn something
Ghost jack your car up and shake the tyre...
I think i should be able to test the type is shaking or not...
i think if the bearing is no good it will rattle a bit
AE-101
1.5 J-Spec Engine
Old 06-06-2005, 11:46 AM   #6 (permalink)
check the tire......looks secure.....however, when you try to spin the tire in the front it doesn't want to......eg only makes about 1 revolution before it stops?......is that normal?......its like that on both sides, but the drivers side stops faster........not getting any noises from bearings.....Could warped rotors be causing this???......b/c when its hot and i hit my brakes the steering wheel shimmies a bit, but not a lot
Old 06-06-2005, 05:17 PM   #7 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Sounds like your rotors just need to be turned.
Old 06-07-2005, 04:49 AM   #8 (permalink)
Change it maybe...
Rotor Problems or drive shaft...
AE-101
1.5 J-Spec Engine
