Help! Removing starter on 1998 Corolla LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2005, 03:24 PM   #1 (permalink)
Addicted To Boost
View sblack13's Photo Gallery
hey i'm having trouble removing the starter off my 1998 corolla. Does anyone know where all the bolts are located. I removed like 3, but I can't seem to find the others that hold the starter on. Thank You.
sblack13 is offline   Reply With Quote
Old 06-14-2005, 03:38 PM   #2 (permalink)
Gameroom cash: $147537
3? Shouldn't it be 2?
Old 06-14-2005, 06:24 PM   #3 (permalink)
homebuilt turbo guru
View 2001rolla's Photo Gallery
A 98 it should only be two bolts.
Here is an image to help ya out...
2001rolla is offline   Reply With Quote
Old 06-15-2005, 03:46 PM   #4 (permalink)
Addicted To Boost
i have the starter removed. But I still need to remove the starter housing on the right. Seems weird. I think it most be connected to the transmission. I don't see how it would come out.
thanks for the help 2001rolla
Old 06-15-2005, 03:49 PM   #5 (permalink)
The housing is one piece with tranny. You don't need to remove that to change starter.
I would help if you let us know why you wanna remove the starter.
Old 09-25-2010, 01:38 PM   #6 (permalink)
View rokacook's Photo Gallery
Cool Starter removel
To those interested in stater removal, here goes; remove air cleaner case, disconnect battery, remove passenger side bottom engine cover, remove lower radiator hose careful to drain antifreeze into suitable container two bolts hold starter on one 14mm on the battery side, not the 17mm one that one is for transmission case, the other is accessed from the bottom of car, but first remove two wires on the starter there is a 12mm nut under plastic cover, then remove lower bolt from starter side 14mm. Starter may be tight a little tap or two will loosen, will come out thru the bottom past the oil pressure sensor and the lower radiator outlet. reinstall in reverse order.
Should take novice less than 2 hours
rokacook is offline   Reply With Quote
