81 Corolla, No clutch play, no gear engagement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2002, 01:39 PM   #1 (permalink)
View PuntoOcho's Photo Gallery
I need help. I went out to drive my car and noticed it had no clutch play. I turned it on and say it wouldn't go into gear either. I check the clutch fluid and it was empty. I filled it with DOT 3 and pumped the clutch about 30 times and still didn't have any play. What else could this be thanks. Peace.
PuntoOcho is offline   Reply With Quote
Old 09-02-2002, 06:48 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
If you drove it like that for a while.. you might have killed your clutch or tranny. always check your fluids man.. at least once a week.
Old 09-02-2002, 07:08 PM   #3 (permalink)
I'm gonna try bleeding the clutch line, hopefully that was it. It also might be the slave master cylinder. My uncle is gonna take a look at it tomorrow.
Old 09-03-2002, 05:00 PM   #4 (permalink)
View jmschoep's Photo Gallery
Yeah something is going on if your out of fluid- make sure all the line are ok while your at it!
jmschoep is offline   Reply With Quote
Old 09-03-2002, 09:07 PM   #5 (permalink)
Thanks for the suggestions. My baby's up and running again. My uncle said it was the clutch slave cylinder. We went pep boys and bought the part ($28) and that is was it was. Thats the second time ive had to replace it in the nearly 2 years i've had it. Peace.
Old 09-03-2002, 10:10 PM   #6 (permalink)
View bondobondo's Photo Gallery
either you drive alot or you use your clutch ALOT
anyways, hydralic systems for clutches use a master and slave cylinder,
if you have had to replace the slave 2x, in the last 2 yrs, then i think the leak may be somewhere else.
you may want to take a look at your master cylinder,
climb down low and look at your clutch pedel and trace it up to where it meets the firewall, then look at the plunger thing that connects it to the firewall,
pull back the carpet and look at the firewall below that plunger.
it should be dry, but if it is wet, you now know where all your clutch fluid is going.
slave/master cylinders for clutches last around 100,000kms, so that is ~4-5 yrs of driving.
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
bondobondo is offline   Reply With Quote
Old 09-03-2002, 10:24 PM   #7 (permalink)
1nzfe addict
View toymaniac's Photo Gallery
:o wow evrything is original on mine(234 000km).....???and no problems my uncles 82 celica is 260 000km and its original with no problems....are we just lucky or what?
Toymaniac ADM. ClubEchoQuebec.com
toymaniac is offline   Reply With Quote
Old 09-04-2002, 03:56 AM   #8 (permalink)
View myg0tsephiroth's Photo Gallery
I have an '82 two-door 4-speed corolla, with 121,464 miles on it. I replaced the master cylinder, slave cylinder, clutch disc, pressure plate and had the flywheel machined, all for about $250(cuz i did the work myself) I can tell you one thing though rebuilt part don't last no where near as long as OE parts so once you have it replaced from OE expect to replace it often.
I'm only 19 my mother bought her right before she had me, I grew up with the thing and I love it to death I will never get rig of it. I plan on shoe-horning a 2RZ-FE 2.4L DOHC I4 engine out of a tacoma into her.
myg0tsephiroth is offline   Reply With Quote
Old 09-04-2002, 09:20 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
My clutch is 10years old.... so is my hydraulic parts. I dont know where you got your info, but 10 years isnt that much from a car...
Old 09-04-2002, 06:07 PM   #10 (permalink)
the OE clutch on my car lasted for about 14 years until i moved to Florida from Kentucky, now they go out every year or so.
