haha... sure voodoo! send me your address and info.
drei: My 89 is got a little bit of rust around the fenders.. I replaced the front driver fender and I have the passanger side fender in my dad's garage that I can replace sometime this summer.
As for the wheels... you can go with 15s like I did, I'm running 195/50-15s or 195/55-15 or you can run 205/40-16 or 205/45-16 but to run 205 width rims and tires you will need spacers as the wheels will rub on the inside depending on the offset. The maximum offset you should go is 38-43offset. I'm running a 43offset on my wheels and I have no rubbing issues. For spacer, if you're gonna run 205/40-16 or 205/45-16s you should get a 1mm spacer to give you that much gap between the inside of the wheel and the inside wheel well.
Xenon (Ahmed the traitor) runs 205/45-16s on his SR5 with a 1mm spacer I believe, but I'm not sure what his offset is. Here's his car.
