How to remove stuck oil filter (4AGZE) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2005, 07:47 AM   #1 (permalink)
View ericlee303's Photo Gallery
Since we installed this new 4AGZE, we have never been able to remove the oil filter. It is stuck. We've tried the filter wrench and socket with no luck.
Problem is, it's kind of under the exhaust manifold on my car, and a little hard to get at.
What are you solutions guys?
I'll post pics later
94 JDM 4AGZE Corolla powered by www.sdsefi.com
00 Yellow Integra Type R #795
ericlee303 is offline   Reply With Quote
Old 06-20-2005, 08:18 AM   #2 (permalink)
Gameroom cash: $147537
Try stick a screwdriver through it.
Also Princess Auto got filter clamp that will acturally clamp the filter tight. You should be able to remove it with that.
Old 06-20-2005, 11:40 AM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Get yourself a filter clamp. A round strip of metal on a handle with a screw at the end. That way you can clamp tight like Pineapple has said. You probably already know though, never do them back up with the clamp... always go only 1/2 turn past tight. That way you shouldn't have problems getting it undone again.
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 06-20-2005, 01:43 PM   #4 (permalink)
Thanks guys, we tried the clamp, but no luck. Even the smallest one slips. We can't seem to get enough leverage on the damn thing.
I think the screwdriver will have to work, but the filter is in a wierd spot.
Old 06-20-2005, 07:03 PM   #5 (permalink)
DerekDorifto's Avatar
View DerekDorifto's Photo Gallery
Get the Princess Auto tool for $5, it looks like pliers but it locks like a visegrip. Clamps and crushes any filter, then you just twist and remove it.
Never experienced any oil filter that it couldn't remove, no matter how awkward the location!
AW11 / AE86 / AE100
DerekDorifto is offline   Reply With Quote
Old 06-20-2005, 11:56 PM   #6 (permalink)
Gameroom cash: $134355
what i've done (and my first filter change on the 4age was just like this.... the filter wrench did nothing, by hand did nothing).... used a 15" screwdriver (big/beefy one too), pounded it through with a hammer.... only problem is that it ripped the filter almost in half...... i was then able to use part of the hole as a point to put the flathead part against and pound until the filter spun a bit
cut my hands up pretty good doing that though...... watch out if the screwdriver starts to pull the filter in half
Old 07-19-2005, 11:42 PM   #7 (permalink)
View alxch1n16's Photo Gallery
any luck on the filter? mine got stuck on my camry, i used the princess whatever clamps, they suck and crushed the filter, but you have to angle them slightly and then just twist as hard as you can. i nearly broke my finger, but i got it.
alxch1n16 is offline   Reply With Quote
Old 07-20-2005, 12:18 AM   #8 (permalink)
N/A bites
Tercel GTS's Avatar
Never use a wrench to tighten an oil filter, and even by hand you don't want it much tighter than a gas cap.
I found a way to save a few bucks and get a better oil filter by using those for an MR2 turbo. Has the same threads and valve, same diameter, a touch longer. Plus at my parts store it's cheaper than the short one by $2.00.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 07-20-2005, 02:45 AM   #9 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
Yeah, he got it off. He tossed the guys at the local oil change place a couple of bucks, and they took care of it.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 07-20-2005, 02:50 AM   #10 (permalink)
Needs To Speed
RiZLA's Avatar
View RiZLA's Photo Gallery
when you do remove it, spread a small amount of grease around the gasket to prevent it from ever getting stuck again
RiZLA is offline   Reply With Quote
