Advice on lowering My Car - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2005, 09:28 PM   #1 (permalink)
View arclite20's Photo Gallery
I have a 97 Corolla. I am thinking about lowering it using coilover. I want to lower it 1.5" in the front 1" in the back. I want know if I lower it will I need a camber alignment. i dont want my tires to look lean like some civics or integras i be seeing or will it be fine.
arclite20 is offline   Reply With Quote
Old 06-23-2005, 02:01 AM   #2 (permalink)
homebuilt turbo guru
View 2001rolla's Photo Gallery
If you want to drop it an inch to inch and a half then don't bother with coilovers... The ride will be too stiff and you'll end up buying spring and struts later down the rode anyway.
Go with the Tein H Tech springs and a new set of KYB gr2 struts and you'll get the ride height you're looking for and a smooth bump free ride.
With an inch and a half drop you should not have to mess with the camber too much. I was dropped 2 inches and was at the outer limit of the camber but still within factory limit. If you are running low pro tires then you might want to get camber bolts and have the alignment done right after you lower the car.
2001rolla is offline   Reply With Quote
Old 06-23-2005, 10:46 PM   #3 (permalink)
Ya i think i am gonna go with lowering springs
Old 06-23-2005, 11:31 PM   #4 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $114450
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
I'm on jdm kg/mm coilovers, about 1.5 finger gap in front and 1 in back and I have hella negative camber (that I have to fix) but I'm slammed.
You will need a 4 wheel alignment but no aftermarket camber bolts are necessary in your case.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 06-24-2005, 01:07 AM   #5 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
i'm using sparco lowering springs with OEM Levin superstruts in front and KYB Excel-G at the rear. i barely have 1 finger gap in front and around 2 at the rear.
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 06-24-2005, 01:52 PM   #6 (permalink)
BigWilly ;)
View rated_w's Photo Gallery
I'm running tokico HP struts and Tein S springs.. lowered 1.9 front and 1.3 rear .. very pleased..
rated_w is offline   Reply With Quote
Old 06-25-2005, 06:01 PM   #7 (permalink)
XRSs'n
Corolla_reps's Avatar
View Corolla_reps's Photo Gallery
all i want to see is a slammed Corolla....i think it looks great
TRDXRS...
Corolla_reps is offline   Reply With Quote
Old 06-25-2005, 11:48 PM   #8 (permalink)
BigWilly ;)
slammed enough?
Old 06-26-2005, 09:25 PM   #9 (permalink)
not good for everyday driving
Old 06-26-2005, 10:56 PM   #10 (permalink)
BigWilly ;)
keep in mind that I do have the TRD lip kit .. if you were not to have it there.. there would be more clearance.
Old 06-27-2005, 01:32 PM   #11 (permalink)
XRSs'n
nice one..yeah i think without the kit u'll be running low...but i guess the simpler it is the better...
TRDXRS...
Old 06-27-2005, 02:56 PM   #12 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Holy bluemeanie is all about the JDM look.
