Using a floor jack - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2005, 11:03 AM   #1 (permalink)
Gameroom cash: $232150
View Joe B's Photo Gallery
Using a floor jack
When lifting front or back or from the side to lift the two wheels off the ground where would you position the floorjack lift end?
'11 Camry Hybrid Classic Silver/Ash
Moonroof | NAV | Leather | JBL Audio | XM | Blue Tooth | OEM Remote Start | Michelin Primacy MXV4
'11 Honda CR-V EX-L w/NAV 4WD Glacier Blue/Gray
Leather | Remote Start | Fogs | Premium Sound | XM | Wood Dash | Michelin Primacy MXV4
Joe B is offline   Reply With Quote
Old 06-24-2005, 11:22 AM   #2 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $114450
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
under the frame. then put a jack stand under the solid joint of the appropriate A arm(s).
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 06-24-2005, 02:20 PM   #3 (permalink)
Gameroom cash: $134355
i use the cross-member on the corolla and the rear tranny mount on the mr2...... going from the side with a floor jack bends the tabs in on the side where the factory jack is supposed to go...... can't stand how it does that
Old 06-24-2005, 02:30 PM   #4 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
^ the jack rails collapse very easily.
I was referring to lifting either the right or left side ... front to back toyotaspeed90 is correct. Tho I'd still put the jack stands at any/all of the four corners for stability's sake.
Old 06-24-2005, 09:38 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I always use the rails.. I guess I shouldn't
Which crosmember you talking about?? I'm always afraid to put the jack somewhere else other than the rail because I don't wanna bend or break anything from the weight of the car, but I'm also afraid the floor might go thru or something.
Old 06-25-2005, 12:00 AM   #6 (permalink)
crossmember that goes forward/backward right under the tranny....... it's beefy, it can handle it
Old 06-26-2005, 12:59 AM   #7 (permalink)
foodaa's Avatar
View foodaa's Photo Gallery
AE92
The tabs do bend too easy.
Here is where the manual says to put the jack.
http://www.ae92gts.com/ae92gts_jack.html
foodaa is offline   Reply With Quote
Old 06-26-2005, 02:44 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
No shit, I bent them when my car bottomed out on a supermarket offramp.
