96 Corolla Gas tank - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2005, 12:34 PM   #1 (permalink)
View gfreek's Photo Gallery
96 Corolla Gas tank
What problems will I encounter putting in a new gas tank ????
gfreek is offline   Reply With Quote
Old 06-24-2005, 01:17 PM   #2 (permalink)
XRSs'n
Corolla_reps's Avatar
View Corolla_reps's Photo Gallery
gasket, stock gas tank itself it is damn heavy...rusted knots and bolts...u may need some other peeps to help u out...otherwise good luck
TRDXRS...
Corolla_reps is offline   Reply With Quote
Old 06-24-2005, 03:23 PM   #3 (permalink)
Figured that, whats on the top of the tank be sides the sending unit-fuel pump assy, fuel line{ is there a special fitting?}, vent hose etc??? Do you know if a new aftermarket tank comes with the filler neck or do I have to tranfer over the old one,{or get a new one}??
Old 06-25-2005, 10:49 AM   #4 (permalink)
XRSs'n
if ur just changing the gas tank u can use the same filler neck from stock ones..fuel pump just use the old one u have unless if it is done, fuel line should be able to use same unless if it is too rusted( to avoid any linkage u may change it to a new one)..but otherwise u may have to change ur gasket( it should come with the new gas tank)....
anything else u should be fine unless ur running some kind of turbo yeah u may have to change couple of things such as fuel pump etc.......
TRDXRS...
