No diff in the heads. If the salvage car has a 4AFE also, there will be no problem.
You might run into difficulties if the salvage is a 7AFE auto, then the ECU might not match well with the engine I don't think (but would likely still work) and I'm not sure if the auto trannys between 4A and 7A are the same.
In general, the 4AFE will fit and work if the salvage has a 4AFE.
94 JDM 4AGZE Corolla powered by www.sdsefi.com
00 Yellow Integra Type R #795
