92 corolla brake problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2005, 04:43 PM   #1 (permalink)
View glenn35's Photo Gallery
the trouble is very weak pedal goes to the floor checked no leaks at all so changed master cylinder with a used one, no change tried a rebuilt one again no change , so went with the proportion valve still the same bled the system several times . could it be the booster i think i've tried almost everything else .. any thoughts would help thanks glenn
glenn35 is offline   Reply With Quote
Old 06-27-2005, 09:26 PM   #2 (permalink)
View karazy's Photo Gallery
If the thru shaft is broken, there will be no brakes at all and the pedal will have no resistance. If the booster is not working, ie no pressure, it will be like when the engine is not running, pedal hard to push. If the pressure is weak the pedal will get relatively harder as pressure is lowered. Hope this helps.
karazy is offline   Reply With Quote
