93-97 maximum wheel size? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2005, 10:32 PM   #1 (permalink)
View area51's Photo Gallery
Have a 97 dx.. what's the largest wheels I could fit under there with low profile (205 mm or so) tires? I think 18"?
1997 Toyota Corolla DX
area51 is offline   Reply With Quote
Old 06-29-2005, 06:40 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
17s max and that would give you a very rough ride.. 18s would be overkill and you'd be looking at a bent rims if you didn't watch the potholes.
Old 06-29-2005, 07:56 AM   #3 (permalink)
hmmm interesting
Old 06-29-2005, 08:13 AM   #4 (permalink)
does anyone happen to know which offsets would work, or the default offset on the 14" steel wheels?
Old 06-29-2005, 08:30 AM   #5 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $114450
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
I think the oem's are +38 and anything from +38 to +42 or +45 will fit.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 06-29-2005, 08:59 AM   #6 (permalink)
aka TRD_roLLa on CC.com
View ractive_roLLa's Photo Gallery
im on 205/40/17 w/ eibach prokit
its actually not that rough
ractive_roLLa is offline   Reply With Quote
Old 06-29-2005, 11:18 AM   #7 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
just to clarify... "205" has nothing to do with the profile of the tire... its the aspect ratio that you want to look at... i.e. "40", "45", "50", "55", etc.
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 06-30-2005, 08:38 PM   #8 (permalink)
View automatic's Photo Gallery
This doesn't address your wheel issue, but if you go to www.tirerack.com , you can find the specs on many tires. This will give you the outside diameter of the tire for comparison to what came on the car, or other Toyota's with the same derivative suspension.
automatic is offline   Reply With Quote
Old 07-01-2005, 12:11 PM   #9 (permalink)
KDM is in
REN69's Avatar
that's probably the lowest you can go right? would you be able to fit 205/45-17s if you wanted or is that impossible?
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 07-01-2005, 01:48 PM   #10 (permalink)
well if i was stock height, i could probably get away with it..
probably rub once in a while over bumps
205/40/17 i never rub and im dropped on eibach prokit
Old 07-01-2005, 05:26 PM   #11 (permalink)
KDM is in
REN69's Avatar
Yeah.. the prokit is what.. 1" drop? any 1.5" or higher you'd probably rub
Old 07-03-2005, 08:44 AM   #12 (permalink)
View arclite20's Photo Gallery
17" Recommended
arclite20 is offline   Reply With Quote
Old 07-03-2005, 05:52 PM   #13 (permalink)
View Nx2k's Photo Gallery
my stock offset if 40 but then again my stock wheels are alloy
Nx2k is offline   Reply With Quote
