Speaking of oil changes... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2005, 03:27 PM   #1 (permalink)
Gameroom cash: $232150
View Joe B's Photo Gallery
I just finished my first one on the '05.
Mobil 1 and a Wix(NAPA Gold) filter.
Very easy.
Two things I learned.
I won't use the Fumoto quick drain plug for the first time in a long time in my vehicles.
I don't like the way it sticks out beyond the oilpan.
Could be a problem if the wife or me should run over something.
I didn't have a new washer for the stock plug.
Hope it doesn't leak.
Hasn't yet.
Also learned even though that filter is tiny you should fill it with oil.
I had a couple of seconds of some scary noise on initial startup.
The change does take 10 minutes like someone mentioned.
'11 Camry Hybrid Classic Silver/Ash
Moonroof | NAV | Leather | JBL Audio | XM | Blue Tooth | OEM Remote Start | Michelin Primacy MXV4
'11 Honda CR-V EX-L w/NAV 4WD Glacier Blue/Gray
Leather | Remote Start | Fogs | Premium Sound | XM | Wood Dash | Michelin Primacy MXV4
Joe B is offline   Reply With Quote
Old 06-30-2005, 03:46 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I never fill mine with oil
Old 06-30-2005, 04:20 PM   #3 (permalink)
My Corolla make some funky noise till the oil filled and flowed through the filter.
Old 07-01-2005, 08:30 PM   #4 (permalink)
View Minou's Photo Gallery
Didn't notice any noise on mine but the oil pressure light took about 2 seconds to go off. Usually it goes off immediately when the engine starts.
But I forgot to pre-fill the filter. Will do it next time around. Easy on the Corolla with the filter open end up.
Minou is offline   Reply With Quote
Old 07-04-2005, 07:28 AM   #5 (permalink)
View rs97ap's Photo Gallery
How can I remove the oil filter from a 2005 Corolla? I failed to remove it with my hand, I failed to remove it with a plastic oil filter wrench. Any advice on what type of wrench should I use?
rs97ap is offline   Reply With Quote
Old 07-04-2005, 08:44 PM   #6 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
What Wix / Napa filter did you use? 1394? If you have clearance, you can fit the Napa 1396 filter on there if you want. It is about 1/2" longer than the 1394 filter. My 2.2l Camry supposed to use the 1394 but I put the 1396 on there and I haven't seen ill effects from it.
If you cannot remove it with the wrench, last resort is destruction method. Use a pair of channel locks or a a screwdriver.
2007 Camry 2.4L 5M
Old 07-04-2005, 10:35 PM   #7 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Vim Adjustable oil-filter wrench $15, will take any filter off in a hurry....Radd Guy....
Raddman is offline   Reply With Quote
Old 07-05-2005, 11:51 AM   #8 (permalink)
Thanks guys - I will try that wrench and see what happens. I can't believe Toyota tightened the filter sooo hard. I didn't buy that wrench in the first place because there is barely enough space to my hand - let alone that wrench... This will be the project for this weekend...
Old 07-05-2005, 12:58 PM   #9 (permalink)
Official Acura Troll
View 02RSX90camry's Photo Gallery
i had that problem in my rsx, where the filter is tiny as fuck (so no filter wrench i got would get it off) and it was super tight cuz firestone did the oil change last time. I found that if u run teh car, so that it gets nice and warm, then take it off, it should come right off using your hand.
02RSX90camry is offline   Reply With Quote
Old 07-05-2005, 02:05 PM   #10 (permalink)
Darkside Cut Me!!!
Gameroom cash: $136123
View Hajoca's Photo Gallery
http://www.lislecorp.com/tool_detail.cfm?detail=1114
Is the tool of choice for the smaller filters, and a 'flex head' socket wrench driver works wonders!
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 07-05-2005, 02:14 PM   #11 (permalink)
I don't think that'll work on an '05.
I couldn't use a band wrench.
Not enough room to turn the filter.
The 'flex head' socket wrench driver Hajoka mentions would work very well.
I didn't have one but I was fortunate the Toyota dealer who did the first change(free)hand tightened the filter.
So with a strip of sandpaper around the filter I was able to get it off with just my hand.
Hand tightening is all that needed.
Old 07-05-2005, 02:29 PM   #12 (permalink)
Registered User
Raddman's Avatar
USA
It works jujst fine on an 03 and its the same engine....anyways I went to a K&N filter it has its own takeoff nut ...Radd Guy...
Old 07-05-2005, 02:31 PM   #13 (permalink)
OK..I'll take your word for it.
Hastings filter at one time had that nut on the bottom of the filter.
It's a great idea.
Old 07-05-2005, 02:50 PM   #14 (permalink)
Resident asshole
Flashmn's Avatar
screwdriver through oilfilter + twist = filter in hand.
Old 07-05-2005, 02:52 PM   #15 (permalink)
Registered User
Raddman's Avatar
USA
It's a great idea.
I like it because you can use it almost in a vertical position(only way you can get at that filter)...My first "do it myself" oil change I used a regular channel lock and it came off after a little sweat..but your right it sure is tight in there...Radd Guy...
