yup, that was the trick... I thought (before posting) that it may have one but I couldn't see it...not a lot of room to work up there.. got that off no problem after that.
the door handle was a little tricky..it has 1 screw and I thought it would just come off...NO.. you have to slide it to the front a little, then it comes out.
Once I got the panel off, it took me a little while to figure out how the linkage was supposed to go together...its hard with out looking at one that is put together properly... finally I gave up trying to everything from inside the door panel and I took that outside handle off, then it was easy to figure out cuz you could see the whole picture... fixed it up easy after that. Now I can use my key on both sides (oh the simple pleasures
