20v --> squeaky sound when revv'd.....dangerous? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2005, 12:16 PM   #1 (permalink)
.....drifto time.....
View etxxz's Photo Gallery
I've just had a fresh 20v swap. Everything works, the car runs/starts nicely, has a semi-rough idle, i think because of the distributor (crack cap?)
In any case i'm worried about a VERY LOUD squaking sound the car makes when its revved above 1000rpm and below 3000rpm. It first started when the roads got wet and now its just there. i opened the hood and it seems to be coming from the passenger side of the engine...probably towards the front. What can it be? alternator dying?
^sound goes away once i'm past first gear. (rev'd over 3k and moving)
I lost my power steering tensioner pulley in the highway, took the belt and so i have no power steering right now, wondering if there's a way to run a belt from the crank to the p/s pump directly.
etxxz is offline   Reply With Quote
Old 07-02-2005, 12:51 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Belt slipping
Old 07-03-2005, 09:04 AM   #3 (permalink)
o man lets hope its that. you sure is not like the alternator dying or something like that?
i'm put some tension on that belt right now. THANKS flash. i owe you anotherone
^^but seriously, i do owe you for all the help!
Old 07-03-2005, 09:11 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
heh, its not that big of a deal, two words and two mins, you need to tighten the belt by prying the alternator out a bit with a crowbar, etc. Alternator dying wont really make a whine, it will just not charge enough.
Old 07-03-2005, 10:16 AM   #5 (permalink)
View karazy's Photo Gallery
Just don't make it to tight, or you will toast the front bearing on the alt.
karazy is offline   Reply With Quote
Old 07-03-2005, 11:16 AM   #6 (permalink)
got it.
i just tighten a bit the tensioner pulley he sector b/ the alt and the water pump is still kinda loose, but it made the belt sector b/ the alt and the crank tight.
and yup, its the belt. i'ma play around and see how to tighten this...i dun have a crowbar or something i can use as one
<---look under etxx.
Old 07-03-2005, 02:47 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
hehehehe
Old 07-03-2005, 03:28 PM   #8 (permalink)
prob fixed...cost me a trip to tire kingdom where a friend pryed the alternator...yei
no i have a problem of bald tires...my frikin tires dont even 2months on this car
Old 07-03-2005, 05:40 PM   #9 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
That semi-rough idle your talking about is the probably Idle Speed Controler located just below the throttle bodies on the intake side. I had the same problem. It's because they have been sitting doing nothing for so long. Unfortunately the part costs $800 from a dealer, but there is good news - you can pick one up off of a later model 4A-FE for next to nothing, because the wreckers dont know how much they are really worth.
Is it still rough at high rev's? If it is, then clean your dizzy cap and look for cracks.
*Edit*: the part number starts with 22270 too.
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 07-07-2005, 06:35 PM   #10 (permalink)
dizzy cap seems to be craked...or so says my mechanic friend. there's one on ebay for $50 w/ rotor...mine baby...
TY all.
"Charles Xavier, from X-MAN tried reading Jack Bauer's mind once and now he's on a wheelchair"
99 A 3.2TL Nav | 88 332is [rip] | 88 332is ; ]
86 Ae86 20v, trd susp&lsd [sold]
